Whats the difference or advantage between 3mb or 6mb of graphics card memory? please
Using my 3Gb 780 ti @ 5760x1080 (desktop spanned over three monitors) the 3Gb isn't enough for maximum settings in games like Battlefield 1 & 4 as the large resolution uses more VRAM than the card has, if I drop the resolution down to 1920x1080, effectively one monitor, I can pretty much max out whatever I throw at it.
That's the difference between 3 and 6Gb VRAM for me anyway.
For this reason I'm getting an 8Gb 1070 soon, if my 780ti had say 6Gb I very much doubt I'd need to upgrade it, shame, bar the limited VRAM it's a terrific card still.
Having owned a 780ti previously I'm not sure it could push 6.2 million pixels around the screen to a satisfactory degree, that's 3/4 of 4K and my 1060 (an improvement on the 780ti) wouldn't come close to it unless I chose lower quality settings.
I think it's worth bearing in mind the card performance when you look at memory amounts. A 1060 at 3 or 6gb is a low end card really and whilst you can give it 6gb it may not have the power to max that vram. It's like putting an expensive set of tyres on a Ford Fiesta. It can't really maximise their potential.
