graphics card reccomendation please
28 Aug 2013
hello
just started to use fusion 360 and it recommended i should upgrade my card could someone please recommend me a card thank i may play a game if my m board is up to it? really not sure
thank you
Quite frankly, anything card you can get your hands on (in stock) summat like 1650super, 1660, 1660super, 1660ti, rx570 8gb, rx580 8gb These last two are fairly easy to get, but all the others are as rare as hens teeth absolutely anywhere.
If you already have something similar, then maybe a 2060, 2070, rx5600xt, rx5700, 5700xt
Does it actually matter with this tool? I don't know how it works, but often the graphics cards just displays the models, or does a little bit of secondary work. What's the benefit you'll get from upgrading?
I used to use that just for the cam to go on CNC machines, fairly simple parts but some more complex ones like full turbines, my gtx1080 was more than enough so any midrange card will do fine I think, I don't think for my purposes a quadro/firepro would have made a difference
edit: get at least 16gb ram, maybe 32 if you're doing complex work. That's the one thing that will grind it to a halt
