Graphics Card Ruined?
19 Nov 2003
Just turned on my PC and I have lines going down the screen each made of blocks of colour and 3D is covered in blocks too, I assume this means I'm screwed? :)
If so can anyone recommend a replacement for a 9800pro, problem I have is the replacement cannot be any longer or it wont fit in the case :/ I'm planning on a whole new computer in the new year anyway but need tiding over till then.
edit: got a screenshot:
looks borked to me. I used to have a 9800. think i still have a 8500 and 800xt pe in my drawer. What size is your card?
Jobe
My card is about 17cm long, any longer and it will get stop me connecting up my hard drives, the artic cooler is already millimetres off stopping me using the bottom 2 drives the card itself isn't much further off the top drive.
Can you mount the drives somewhere else, like in the floppy bays?
I think most of the decent AGP cards (7600/X800) are longer than 19cm, as they have 256Mb ram or more.
