- 25 Jun 2009
Hi, I'm looking to upgrade my PC to handle 10 monitors and I would like some advice on the best card or cards to buy.
I would prefer the fewest number of cards
I do play a few games such as Portal and soon Skyrim but this PC is mostly used for web programming and server monitoring etc.
I must be able to use each monitor individually for applications
It would be nice to allow games to run over all monitors (or at least the middle 6)
My monitors support DVI and VGA (I prefer DVI so I can run them at 1920X1080. Not sure if it's my current cards but VGA doesn't work above 2Hz on that res).
I don't mind using convertors (for display port etc)
I've heard of a card that supports 12 monitors (Powercolor HD 5970) but I can't find anywhere that sells it.
