You putting WC blocks on the GPUs? That should make them solid, if the screws are nice and tight there should be no drooping at all. If not then a solution like above would work![]()
I knew someone would link this. It is not in stock anywhere and EOL. It's not on ebay.
NEXT
Google must be wrong then.
