Graphics Card Suggestions?
29 Mar 2009
So here's one to laugh about, Anyone suggest a card i can fit in there?
Thanks in advance!
Mobo info:
Motherboard Name Foxconn 945GZ7MC (Lucknow)
Front Side Bus Properties
Bus Type Intel AGTL+
Bus Width 64-bit
Real Clock 200 MHz (QDR)
Effective Clock 800 MHz
Bandwidth 6400 MB/s
Memory Bus Properties
Bus Type Dual DDR2 SDRAM
Bus Width 128-bit
DRAM:FSB Ratio 8:6
Real Clock 267 MHz (DDR)
Effective Clock 533 MHz
Bandwidth 8533 MB/s
Motherboard Physical Info
CPU Sockets/Slots 1 LGA775
Expansion Slots 2 PCI, 1 PCI-E x1
RAM Slots 2 DDR2 DIMM
Integrated Devices Audio, Video, LAN
Form Factor Micro ATX
Motherboard Size 220 mm x 240 mm
Motherboard Chipset i945GZ
Company Name Hon Hai Precision Industry Co., Ltd.
here's everests summary :D
Field Value
Computer
Computer Type ACPI Multiprocessor PC
Operating System Microsoft Windows XP Professional
OS Service Pack Service Pack 3
Internet Explorer 8.0.6001.18702 (IE 8.0)
DirectX 4.09.00.0904 (DirectX 9.0c)
Motherboard
CPU Type DualCore Intel Pentium E2140, 1600 MHz (8 x 200)
Motherboard Name Foxconn 945GZ7MC (Lucknow) (2 PCI, 1 PCI-E x1, 2 DDR2 DIMM, Audio, Video, LAN)
Motherboard Chipset Intel Lakeport-G i945GZ
System Memory 1015 MB (DDR2-667 DDR2 SDRAM)
DIMM1: Hynix HYMP564U64CP8-Y5 512 MB DDR2-667 DDR2 SDRAM (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)
DIMM3: Hynix HYMP564U64CP8-Y5 512 MB DDR2-667 DDR2 SDRAM (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)
BIOS Type AMI (05/29/07)
Display
Video Adapter Intel(R) 82945G Express Chipset Family (128 MB)
3D Accelerator Intel GMA 950
Monitor Wise Wing MW19E-AAA [19" LCD] (002974)
Multimedia
Audio Adapter Realtek ALC888/1200 @ Intel 82801GB ICH7 - High Definition Audio Controller [A-1]
Storage
IDE Controller Standard Dual Channel PCI IDE Controller
Storage Controller MagicISO SCSI Host Controller
Disk Drive Generic- Compact Flash USB Device
Disk Drive Generic- MS/MS-Pro USB Device
Disk Drive Generic- SD/MMC USB Device
Disk Drive Generic- SM/xD-Picture USB Device
Disk Drive Hitachi HDS721616PLA380 (160 GB, 7200 RPM, SATA-II)
Disk Drive SanDisk Cruzer Blade USB Device (1907 MB, USB)
Optical Drive HL-DT-ST DVDRRW GSA-H30L (DVD+R9:8x, DVD-R9:8x, DVD+RW:16x/8x, DVD-RW:16x/6x, DVD-RAM:12x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW/DVD-RAM)
Optical Drive MagicISO Virtual DVD-ROM0000
SMART Hard Disks Status OK
Partitions
C: (NTFS) 149.0 GB (83.0 GB free)
Total Size 149.0 GB (83.0 GB free)
Input
Keyboard HID Keyboard Device
Mouse HID-compliant mouse
Mouse PS/2 Compatible Mouse
Network
Primary IP Address 192.168.0.101
Primary MAC Address 00-06-4F-6A-82-D4
Network Adapter Realtek RTL8169/8110 Family Gigabit Ethernet NIC (192.168.0.101)
Peripherals
Printer KODAK ESP-3 AiO
Printer Microsoft XPS Document Writer
USB1 Controller Intel 82801GB ICH7 - USB Universal Host Controller [A-1]
USB2 Controller Intel 82801GB ICH7 - Enhanced USB2 Controller [A-1]
USB Device USB Composite Device
USB Device USB Human Interface Device
USB Device USB Mass Storage Device
USB Device USB Video Device
DMI
DMI BIOS Vendor American Megatrends Inc.
DMI BIOS Version v5.05
DMI System Manufacturer Compaq-Presario
DMI System Product GM274AA-ABU SR5109UK
DMI System Version
DMI System Serial Number CNX7253TTN
DMI System UUID F00989E4-7422DC11-B7E23C8C-99144CE2
DMI Motherboard Manufacturer Foxconn
DMI Motherboard Product Lucknow
DMI Motherboard Version 1.0
DMI Motherboard Serial Number ULP872209654
DMI Chassis Manufacturer
DMI Chassis Version
DMI Chassis Serial Number
DMI Chassis Asset Tag
DMI Chassis Type Desktop Case
DMI Total / Free Memory Sockets 2 / 0
ok sweet but ima take some photo's of my pc inside then show them on here, how long you on for if you can take a look for me ? cheers
With the E2140 at stock speed, it probably would cripple the performance of even the entry/mid level gaming graphic cards:
http://xtreview.com/addcomment-id-2106-view-Pentium-e2140-benchmark.html
I think you should overclock your CPU first, before getting a new graphic card.
The E2140 is capable of overclocking from stock speed 1.60GHz to around 3.00GHz...but it would depend on if your motherboard is up to the job.
Here's a video for your reference:
