Graphics Card to Buy, Help
23 Dec 2008
UK
reccomend a good Graphics card to buy!
it must be under the 280 Gtx performance wise and also it must be very cheap. £100 Budget.
preferably ATi
The ATi 4870 is the closest it can be to just right under the performance of the GTX280, so unless you can get it second hand or something, £100 is pretty much impossible for this.
The 9800GT or 4830 can be had for just under or around £100. Both are great performers for their price.
For just a little tad more over £100, the 9800GTX+ or 4850.
