Graphics card to run 4 displays
Caporegime
24 Dec 2005
Autonomy
Currently running two ATI cards one 4350 connected to amp via HDMI and the 4870 connected to 3 monitors
Would be nice to have just one card to save power etc....
What are my options?
Ideally would like to bitstream HD Master Audio over HDMI
Cheers
I believe there is a Powercolour 5770 that can run 5 monitors. The graphics power should be very similar to your existing 4870.
Will you be doing anything intensive on the cards? If not, I would probably suggest a pair of 5450 or 5550/5570 cards. They will each have more graphics power than the 4350 and use much less power the current system.
1GIG zotec 460 won't be gaming in high detail if it's over 4 screens imo...not enough RAM
I just want to game casually on one 24" Dell
The other monitors are for studio stuff
The fourth output is for the Onkyo 876 amp this is linked to my projector in my cinema room
Go for the 5770 its a good card ran fine on my 24" monitor
But will that run 4 displays?
I have the option of running the 4870 1GB for games and getting a 5450 HDMI for output to my Amp and this will bitstream HD master Audio?
Am I ok to run a 4870 and 5450 side by side or will there be an issue with drivers?
Thanks cmndr_andi
I guess the cheapest route would be to keep the 4870 1GB for games and get a 5450 for output to the amp?
Would the drivers allow his?
I imagine that would work fine. The audio chip on the 5770 is recognised as a separate audio device in windows ("hdmi playback device" I believe). If you switch over to that audio device when you want to run the amp then it should all work fine.
not sure how that would affect bluray playback if your using a separate audio and video outputs (HDCP and all that lark). I wouldnt bet on it working without doing some research first.
If that card is connected primarily to the amp (providing audio and video to the home theatre) then I don't see the problem. It would just require switching the audio device over to the 5000 series card before playing the blu ray (or whatnot).
Basically the exatcly what the 4350 does now. Outputs Video and audio to the amp
I was just wondering about running a 5xxx series card and a 4xxx series card togther
