Graphics Card Upgrade Advice
2 Feb 2012
Hello I'm looking to buy a cheap graphics card for my Dads computer which would be able to play games like Train Simulator 2014 at Max settings.
Currently the card he has is the GT 220 and it runs the game on low settings, I'm looking to spend up to £100 maybe abit more if it's worth it but also want to try buy it from a retail store e.g. PC World if possible.
Other things I should mention is space inside the case is limited as he only has a Medion PC MT 7 (Type - MED MT 516) Below is a link to the insides of what the computer looks like.
http://img37.imageshack.us/img37/7700/img1161z.jpg
Thanks
Hi thanks for the advice on the cards but I forgot to mention some other facts
PSU is only 350w https://www.dropbox.com/s/q55i9osrgk2o9li/2013-12-11%2014.15.17.jpg?m=
CPU is; Intel Core 2 Quad CPU Q8300 @ 2.50GHz, 2499 Mhz
4 gigs of Ram,
2 dvd-re drives
usb 3.0 card inside
so I'm not sure if the PSU will be enough to power it all.
Really all I'm looking for is a card that will play Train Simulator 2014 & Flight Simulator at Max graphics as these are the only two games he plays.
Well I was thinking of trying to buy a 450w - 550w replacement, but thing is I'm on a budget and can't really afford allot to spend on both.
What screen res does he game at? Train Simulator 2014 needs quite a beefy pc to run everything maxxed out especially routes like WCML and SECML. Flight simulator is even more demanding even though it's older, especially with scenic add-ons.
The psu is not too bad. At least it's a decent brand and has 300w on the 12v rails. Does it have a pci-e plug? Can't see one in the first piccie.
