I’m running a Dell Dimension E520 brought in June 2007 which has served me reasonably well for the last 5 years. It has an Intel Core 2 Duo processor (6320) running at 1.86GHZ and an ATI RADEON X1300 PRO 256MB graphics card, both original to the system. I’ve upgraded most other components over the years so the system now has 4GB DDR2 800MHZ memory, Windows 7 Home Premium 64 bit and a Samsung Spinpoint 1TB Hard Drive, all of which were worthwhile upgrades. I get a 4.1 Windows Experience score (Processor 4.9, Memory 5.4, Graphics 4.7, Gaming Graphics 4.1, Primary Hard Drive 5.9). The graphics is the Achilles heal, and this is where I’m now struggling.
I don’t use the computer for gaming, but I’ve recently brought a Sony digital camera and can’t get the HD videos (1080p .MTS files) to play back properly. They play back best in Windows Media player but are noticeably juddery. They’re unwatchable with VLC media player. Previously I’ve noticed BBC iPlayer playback to be slightly juddery but don’t use this on the computer now I’ve got an internet enabled TV, which plays iPlayer perfectly.
I’ve been considering upgrading the graphics card to rectify the problem, using the comparison tool at http://www.gpureview.com/show_cards.php as a guide. I’d prefer a passively cooled card like the one I have now both to keep things quiet and avoid any unnecessary strain on the PSU, and have come up with 3 possible candidates:
Sapphire HD 5450 1GB DDR3, currently around £25. 4 times as much memory but most specs only marginally better than my card, except for memory bus which is actually worse (64 bit down from 128 bit)
Sapphire HD 6570 1GB Ultimate, currently around £50. Double the price but would comfortably outperform my card in every way.
Sapphire HD 7750 1GB GDDR5 Ultimate, currently around £100. Higher spec still, but more than I would ideally like to pay.
It’s worth noting that I’ll probably be replacing my system completely within the next 12 to 18 months, so I would rather not go too overboard. If the cheaper 5450 card would solve the issues I’m having then I’d happily opt for this as my preferred option, but if it would make little or no difference then I might be tempted to opt for the 6570, but only if I would see a significant improvement. I think I’d only really consider the more expensive 7750 if I were to consider using it in my new system, but if it isn’t towards the end of next year when I eventually upgrade I’ll probably want to be looking at something newer.
My other option is just to live with it for now if the cheaper card isn’t likely to fix things.
The next consideration is how far I can go with my system before I hit the next bottleneck, which I’d imagine would be the processor, so I don’t want anything too higher spec if my system wouldn’t be able to take advantage of the extra power of a more expensive card versus a cheaper one. I really don’t want to be upgrading the processor or anything else, I’d rather save the money for when I get a new computer when I wouldn’t mind spending more.
Any information or advice would be gratefully appreciated as well as suggestions for alternatives.
Thanks.
Tim
Thanks.
Tim
