- 27 Mar 2012
My first post to the forums so sorry If I mess this up, I will type out my spec and what Im wanting to upgrade and tell me if its worth it, I though I would put it in this part of hardware as I think my graphics will need updated the most.
My System specs
fx bulldozer 6100 3.3ghz got it running around 3.9/4.0ghz
8gigs corsair vengeance ram 1600mhz
my motherboard is = http://www.asus.com/Motherboards/AMD_AM3Plus/M5A97
Monitor is = http://www.overclockers.co.uk/showproduct.php?prodid=MO-005-AO so its capable of running on crossfire
and my current gpu is = https://www.overclockers.co.uk/showproduct.php?prodid=GX-131-MS&tool=3
Before you's lot say anything I was using it with my previous cpu q6600, it finally gone out of the window hence the upgrade to the bulldozer.
So I want to know my options on which gpu to go for, I mainly play battlefield 3 as everyone else now a days, But i want to play with higher graphics instead of low, and still get over 60fps but id rather not spend over £250, If i can how ever get 2 lower cards for the same price that gives better performance let me know. preferable something newer than =
XFX ATI Radeon HD 6870 Black Edition 1024MB GDDR5 PCI-Express Graphics Card
Sorry in advance I may not have got my point across thanks in advance
My System specs
