graphics card volts
Permabanned
1 Sep 2007
Norn Iron
atm i'm on stock volts for my 8800gts and it's at about 70ish load so i thought i could get a better oc if i upped the volts a bit yea?how? so what's the stock volts and what should i increase them to?
Volt mod is the only option.
M
Which is what i though.. to volt mod, you will either need a pencil, or some resistors and a damn steady hand for soldering...
Google volt modding your card, may be a pencil mod for it, but as far as im aware, there are no pencil mods for the 88 series cards.
Found some pencil volt mods for the 88gtx, and there were some mentions of gts volt mods, so take a scan online mate, you could be in luck
