Graphics card what to pick
6 Apr 2009
Derbyshire
Hi all. My brother is at it again. Since i upgraded on monday he cant stop ordering new stuff haaaa.
So looking at nvidia gpus. Since i have the new 560ti msi hes been thinking get that.
I said for that little bit extra get the 570.
Just looked at all the 570 and quite a few to select. Any reccomendations on which would be the best. That phantom edition looked like it has great potential.
Or if there is some other cards to consider i am missing.
Sorry to ask again but thanks to all that help.
Have you not seen the GTX 480 for less than £200?
HERE
It's a cracking deal, infact I'm going to order one my self :)
EDIT: Mine will be here Tuesday.
Nice some how missed this haaa need to go back 2 spec savers.
I imagine only real differnce between this and the 570 is 480 will run hotter more power consumption etc.
Well thats hardley anything to grumble at considering you save over 100 notes.
Thanks for that one dude.
Yeah, in terms of fps they are on par with each other.
If later you are unhappy with the noise/heat level then just get an aftermarket cooler and still have money in the pocket.
The 480 is the better card,no?
More Vram.
Higher Memory Interface.
Better Overclock with the 480 over the 570.
Of course the 570 runs cooler and is quieter.
