Graphics card with HDMI inc Audio
8 Nov 2005
Nuneaton
I would like to connect my PC to my LCD TV via HMDI (video and audio). I am not planning to play games.
So, what graphics card would you recommend?
Can you recommend a specific card?
I want to make sure that the only other thing I need except for the card is the HDMI cable. I don't want to have hunt down any DVI->HDMI dongles.
Is everything I need available from overclockers?
xpertvision hd 2600 pro
comes with hdmi onboard (not a dvi converter)
all my vids play smooth as hell now, best £40 i've spent for a while
Is your LCD exact 720p or 1080p resolution? If it's not, you will get a better picture from VGA or DVI as you can match the native resolution of your monitor.
I have a panasonic TX-LX32LXD, I know it supports 720p but I think the native resolution is 1366 x 768.
Depends if you want sound and what sound through the hdmi too.
Only need stereo as that is all my LCD TV supports.
With VGA or DVI you can set your resolution to 1366 x 768 in Windows so your PC to LCD mapping will be 1:1 giving the best picture. I doubt it makes much difference when watching a film but I imagine it would if you we're to use it as a desktop (reading etc.).
With HDMI you could only chose 720p which is 1280 x 720 which is not 1:1 mapping. Ideally you could have both connected, HDMI (because of HDCP) for Blu-ray/HD-DVD and VGA/DVI for desktop.
