Graphics card with HDMI?
25 Jul 2004
I have just bought a shuttle to use as a media centre with my TV, are there any graphics cards (or something along those lines) that have a HDMI port?
Thanks
Hey MeatLoaf - there will be no gaming at all, simply playing full HD movies etc. Ideally I want a single slot card, but a dual will be OK too because I cant imagine I would need to use a second PCI slot for anyting.
Whats your budget? If youre not gaming then id sayits pointless getting an expnsive card just for HDMI
Ive had an 8600GTS, 9600GT and 8800GS all with HDMI but i dont think nvidia cards pass audio over HDMI
If it was me id be looking at something like a radeon 3650
ATI cards come with a DVI to HDMI connector which just connects straight to the back of the card, you then just use a normal HDMI cable and you're sorted, no need to find a DVI to HDMI cable.
Gainward ATI Radeon HD 3850 Pro comes with onboard HDMI really good for the cash but only if you don't mind the sound it crates lmao.
http://www.overclockers.co.uk/showp...3 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
I have one in my HTPC but i got this aswell for it as it was doing my head in hehe.
http://www.overclockers.co.uk/showp...&name=Zalman VF900-CU Quiet Copper VGA Cooler
Its much better than the stock cooler, just installed mine a few mins ago it's silent and temp are lower than the stock cooler with the fan on the lowest rpm :D
