Okay so I see the deal on the 7900 GTO which I was going to get. But I will no doubt need a new power supply, considering the one I have right now is only 350 W, and is underpowered im pretty sure (system restarts randomly).
Anyway I was choosing from power supplies, I was looking at the 520W OCZ OR THE 600W OCZ silent SLI. So I wasn't sure one which power supply to get, is the 520 W OCZ enough?
Also is this card worth getting, with DX10 around the corner. Even though DX10 is around the corner I wouldn't buy it right away, drivers may not be fully stable etc. And the price, which would take at least a few months to settle. Current system specs are:
P4 3.4 GHZ dual cpu
1GB RAM DDR
Geforce 6600 256MB
250GB Sata HD
350W Power Supply
P4 3.4 GHZ dual cpu
1GB RAM DDR
Geforce 6600 256MB
250GB Sata HD
350W Power Supply
You'll be fine wiht that one although if the 600 is marginally cheaper, you may aswell get that one.
