Graphics card
6 Feb 2021
I’m new to pc building, started to build one but common knowledge that the 3080 that I wanted won’t be avaliable anytime soon. Is there any cheaper cards I can buy in the mean time with a good performance that haven’t massively inflated in price?
thanks
If you are not bothered about DLSS the AMD cards appear to have more availability.
3070Ti will be out soon too if the 3080Ti releasing today is out of your price range at £1049
Hate to say this, but if you don't want to spend rip-off amount on literally any graphic card right now, buying a pre-built system is probably the only option...
