Graphics Cards For £100?
If you can stretch a bit I would go after one of the HD3850's for £110-120 ish.
Of course as Jak says what games do you play and at what resolution.
A 3850 would be perfect for that resolution.
Should last you a while as well.
*Although it still won't play crysis at high settings with decent framerates*
guys i know this might sound dumb but i am new to this my motherboard is a ASUS M2N-E SLI which has nvidia nForce 500 SLI Technology does that mean i can only have nvidia cards? sorry to be a noob
Nope you can run any card in a single card configuration.
The fact its a nvidia SLI chipset means that you can only run nvidia cards on it if you want more than one card. (ie you can't run crossfire on it)
For reference I have a Asus P5N-E SLI and I am running a single X1900XT on it now.
No a 8800GT is quite a bit quicker than a 3850 however it also costs quite a bit more. (around the £170 mark versus £120)
Check out a few reviews before making your decision.
(the firingsquad review is pretty good as it shows both the 3850 and the 8800GT along with the older 2900 / X1950pro cards)
because you can get a hd3850 256mb for £105, thats their rrp aswell. the rrp on the 3870 is £140, and you can get them for that, the 3850 512mb rrp is £125 for an overclocked model, so maybe £115-120 for a non overclocked model.
indeed...
Jamemoff if you do want decent gfx please dont buy a lesser card other than the new radeon 3850 or a 8800gt, as the next lot down are seriously compromised in the performance department. try and stretch your budget to one mentioned - they wil be awesomely better than the cheaper ones!
