Graphics cards with 3 HDMI ports
18 Sep 2012
Are there any graphics cards with 3 HDMI ports? Doesn't have to be high speed ports or a massively powered card.
Cheers
Yeah, DP to HDMI adapter(s) much easier. For v specific reasons (I have a semi-complicated multi screen setup) I've ordered one ***elsewhere*** today which has great specs and should do everything I need hopefully.
Don't know if we can directly link ***No you can't *** but it's this description...
8K DisplayPort 1.4 to HDMI 2.1 Adapter [8K@60Hz,4K@120Hz,2K@165Hz] Uni-Directional DP Male to HDMI Female Converter for PC,Laptop,RTX 4080/4090,RX 7900/6900 and More​
It does everything including HDR which I need, but I'm not sure if it supports/ passes through VRR, though for my specifc need I don't need it to in this case, though would be nice for future ref.
2x HDMI isn't that hard to find, do you have a motherboard/CPU with integrated graphics? If so, you could use that, assuming you don't need to game with all three.
Thanks all, appreciate all the replies. I forgot about DP to HDMI adapters, that's a good shout. It's for work purposes rather than gaming with a mixture of monitors and TVs. I'll need to check the screen inputs and go from there. Cheers!!
