Graphics compatibility
23 Sep 2006
Wiltshire
Hello,
Am in dire need of a new graphics card after mine died a few weeks back, I just wanted to check that an ATI 5770 is going to be compatible with my ASUS P5N-E SLI motherboard.
My PSU should be fine as it's a Seasonic M12 600w If i remember right.
What say you chaps?
Thanks.
Basic PCB design is more or less the same, there are versions that come preclocked slightly higher than standard an have slightly better cooling Sapphire vapor-x for example
http://www.overclockers.co.uk/showproduct.php?prodid=GX-222-SP
What i would look for is goodies they come with, bundled games and/or software and more importantly warranty and manufacturer RMA reputation should something go wrong. XFX for example look good in that area, you get 2 yr warranty and there is version with AvP bundeled
http://www.overclockers.co.uk/showproduct.php?prodid=GX-165-XF&groupid=701&catid=56&subcat=1515
http://www.overclockers.co.uk/showproduct.php?prodid=GX-149-XF&groupid=701&catid=56&subcat=1515
http://www.overclockers.co.uk/showproduct.php?prodid=GX-163-XF&groupid=701&catid=56&subcat=1515
I ordered XFX 5870 this morning, seemed like best deal of all available
http://www.overclockers.co.uk/showproduct.php?prodid=GX-167-XF&groupid=701&catid=56&subcat=1502
