Which gfx cooler do you guys recommend?
How easy are they to fit? I have no experiance in how/where to fit them? would be nice if someone explains
Cheers.
In my professional view there is only one try cooler if you don't want to use a WC then take a look at these http://www.arctic-cooling.com/catalog/main.php?cPath=2 awesome coolers and one which I would personally recommend. I used this on my 4970 http://www.arctic-cooling.com/catalog/product_info.php?cPath=2_&mID=101 and it rocked, easy to fit and up and running in just a few minutes.
Although if you have an NVIDIA card then they do these for NVIDIA as well.
Hi mate, 1 of my mates gave me a brand new 'Arctic Cooling Accelero Twin Turbo Graphics Card Cooler'
Im sure thats the one you recommended? im not sure if it supports my card (x4870 x2) Does it?
Also, how do you fit it? I looked it and laughed as i have no idea.
Cheers.
