Hi,
An interesting problem I have with a graphics card. When running 3d applications it seems to run mine though every so often the screen will go corrupt with like a small pattern repeated over the whole of the screen. (will try and post a pic when I get home)
If I alt-tab out of the game it drops into the desktop and all is OK but this can then occur (on the desktop) if I leave the 3d game running in the background; again alt-tab back to the game and the game is OK.
If just run 2d apps then there is no problem at all and I seems to have started a when I updated my graphic drivers. I have tried a couple of drivers (92.xx) since but it still happens (I can’t remember which ones I was on originally) but was in the 9x.xx range. Boot up screen is OK so looks like mem is OK and no artifacts in ati-tool, rthdribl, 3Dmark03/05 (can’t get 06 to install atm cause the d/l keeps corrupting
Is this a driver issue and has any one got any suggestions apart from keep trying drivers until it clears? Or is it something I’ve not thought of.
Card is a Gainward 7900GT with a vf700Cu on it, volt modded so running at 600/1500, rest of the specs are in my sig.
)Is this a driver issue and has any one got any suggestions apart from keep trying drivers until it clears? Or is it something I’ve not thought of.
