- 23 Mar 2008
- West Sussex
I just installed the latest graphics drivers for my 7900, I uninstalled the old ones then installed the new. After restarting my computer now I am faced with this. I use Ultramon for 2 moniters and on startup I got 3 windows, 2 small empty ones you can see there, and another I managed to close which was called something to effect of '72GH7-13EG4-123J....' which was causing my CPU to be at 50% usage. Also on startup up nView started configuring my moniters and changed the resolution and task bar loactions but I got that back to normal. Now I am also faced with the mug you can see, labelled seconds, which I can click on and move about. I don't know if this is a problem, I just thought it was rather strange so should be looked into. Not any funny kind of virus or anything implying I am a 'mug' is it? I am certain my graphics card is on the way out as it gives me artifacts in most new games when under pressure, but I wasn't too bothered by that, because I was sure it stemmed from heat damage when the fan went, but wanted to make sure it wasn't the driver.
Thanks.
Thanks.
