Hi Guys, I think this is the right section, feel free to move it if it isn't.
I've started playing Race Driver: Grid and it's a fun game but something keeps bugging me. On the loading screen there is a car and it has a weird graphics glitch http://i39.tinypic.com/2i795xy.jpg (Note black lines etc).
I'm running the rig in my spec but I've noticed that my GPU is reaching 98 degrees, that seems a bit errm hot.
Would you think this is the problem, if so how can I drop the temps? It has a 120mm fan by the side of it sucking hot air out and the fan on it cranked at full.
It's one of the older GT's with the tiny fan on it.
EDIT* ATI tool still doesn't find any artifacts at 100 degrees but man, that's dam hot. 104 degrees now. I'm thinking I should turn it off
Are there any decent VGA coolers about for the 8800GT?
Cheers
Cheers
It's normal problems with some edges, I'm afraid.
