Graphics Problem???
Have you tried the card in another system?. It may be your PSU but it does kind of look like a memory problem.
I haven't got another system to try the card in. When you say memory do you mean my main memory on the mobo or the GFX card memory?
Graphics card memory.
Elimination is the best way forward in this situation. You've swapped CPU's with no joy so that leaves RAM, PSU and possibly an OS problem.
RAM can be tested with Memtest+ http://www.memtest.org/#downiso - I find running 10 passes of tests 5 and 8 to be sufficient enough to pick up errors. I only run this for a quick stability test so if you have the time or patience then you could leave it to run through all the tests for an hour or two.
You could always try a fresh install of Windows but it will do nothing at all if something else is wrong. So before you do this make sure you have a good think about it.
I've had PSU problems before but all that happened to me was artifacts showing up whilst gaming. I thought my card was dead but a PSU change sorted it and still today it runs in the second PC I built for my mother.
Good luck in finding the problem.
