graphics problem
31 Jan 2006
AMD-8151 HyperTransport(tm) AGP3.0 Graphics Tunnel
i have a yellow flag in my device manager on this above
im running vista 32 and a new 4870x2 i cant get the card installed with any dif drivers, formating etc
but ive always got a flag on my gcard and this hpyer transport error
anyone know a fix let me know thx
i have my latest bios drivers,
is there any other driver you are refering too?
and also i have it running on xp but it wont run on vista this card?
Once in windows you still need to install motherboard drivers and various others depending on OS/Service pack, BIOS versions are completely different. It looks to me as if you're missing chipset drivers or alike.
http://cdrom.amd.com/21860/30204a.pdf < contains info and guides.
Not sure why yours is saying AGP as it should say PCI-X
Sorry
yes the error i am getting is my gcard shows a vga display error in the taskbar when it loads up.
but yes my card is pci-
and really i had a 4870 single card running on vista it was fine
but on vista after removeing of drivers etc,
i just cant get the x2 ati card to install.
i have updated bios
removed all drivers with drivercleaner,.
and i still have this hyperlink error
i know its a vista sware issue but i just cant seem to find what i need to
get it running :)
It should work fine with Vista, if you are getting what you originally posted, its chipset/mb drivers (lack of). The pdf i linked contains info on how to install them and the link LoadsaMoney posted contains the actual drivers (although i dont understand why the amd guide states pci-x and you're saying AGP :s).
...Still No good :E
ok guys ive formated pc.
ive done updates,
i have latest bios version,
on my ASU P5W DH Delux
i still have a pci-pcie bridge error in my device manager,"yellow flag"
and still i have one on the display where it shows the 4870x2"
anyone know exactlly which bios version i should install or try?
or any other Ideas how to fix this PCI-PCIE bridge flag error in my device manager?
ive run out of ideas and its running perfect on my xp install.
just will not run on vista and i dont know how to fix it after format and all clean install of latest drivers?
any help appreciated on how to fix this pci error gladly appreciated :
