Graphics problem
28 Sep 2008
Whenever i play games like crysis, fifa 09 and racedriver grid i get this weird occurance mid game.
It plays fine for around 15-20 mins, then the screen will just change, for example, in fifa 09, i get the arsenal logo as the pitch instead of grass, and sometimes the default setting for player faces projected as the grass.
The players on the pitch don't change, and the markings/goalposts don't change either. I get similar problems with crysis and RD grid.
Only thing OC'd is my cpu, which is stable at 3.0ghz.
Any ideas?
EDIT: screenie of RC grid.
try putting your cpu back to stock even if it is at stable and then run it see if it makes a difference
yeah tried different drivers, it works ok whenever i restart my pc, just done a 24h race on it, all went well. think it might have something to do with when i put the pc on standby :S
didnt used to happen when i had vista64 installed. im on windows server 2003 atm.
I think I see a problem here. Why are you on Server? If you say "just wanted to play about with it" I suggest you look into virtualisation.
I imagine it will be something along the lines of server doesnt have the correct DirectX support, or something along those lines.
