Graphics related BSODs?
16 Oct 2007
UK
Hi all,
I'm having lots of BSODs with a new system, and am a bit stuck!
It's a clean install of (legal, updated) Windows 7 professional. System recently bought from MM. Running 306.23 nvidia drivers. Card is a 570.
Every time I play a game, within an hour, it crashes.
I've installed WhoCrashed, and it comes up with the following report.
System Information (local)
computer name: JAMES-PC
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
CPU: GenuineIntel Intel(R) Core(TM) i7 CPU 930 @ 2.80GHz Intel586, level: 6
8 logical processors, active mask: 255
RAM: 10735828992 total
VM: 2147352576, free: 1941950464
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Sun 23/09/2012 11:54:00 GMT your computer crashed
crash dump file: C:\Windows\Minidump\092312-8907-02.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7F1C0)
Bugcheck code: 0x50 (0xFFFFFFFFC23C2903, 0x1, 0xFFFFF88006B6B7E2, 0x2)
Error: PAGE_FAULT_IN_NONPAGED_AREA
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that invalid system memory has been referenced.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: dxgmms1.sys (dxgmms1!VidMmInterface+0xCF22)
file path: C:\Windows\system32\drivers\dxgmms1.sys
description: DirectX Graphics MMS
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
On Sun 23/09/2012 11:41:36 GMT your computer crashed
crash dump file: C:\Windows\Minidump\092312-8954-01.dmp
This was probably caused by the following module: dxgmms1.sys (dxgmms1+0x39EC0)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF88006D5FEC0, 0xFFFFF880065F76C8, 0xFFFFF880065F6F20)
Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
Bug check description: This indicates that a system thread generated an exception which the error handler did not catch.
On Sun 23/09/2012 10:52:30 GMT your computer crashed
crash dump file: C:\Windows\Minidump\092312-8907-01.dmp
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0xF1D32)
Bugcheck code: 0xD1 (0xFFFFFFFFFFFFFF89, 0x2, 0x1, 0xFFFFF8800F1CED32)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\drivers\nvlddmkm.sys
product: NVIDIA Windows Kernel Mode Driver, Version 306.23
company: NVIDIA Corporation
description: NVIDIA Windows Kernel Mode Driver, Version 306.23
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvlddmkm.sys (NVIDIA Windows Kernel Mode Driver, Version 306.23 , NVIDIA Corporation).
Google query: nvlddmkm.sys NVIDIA Corporation DRIVER_IRQL_NOT_LESS_OR_EQUAL
On Sat 22/09/2012 14:01:24 GMT your computer crashed
crash dump file: C:\Windows\Minidump\092212-9204-01.dmp
Bugcheck code: 0x50 (0xFFFFFFFFFFFFFF8C, 0x1, 0xFFFFF8800FA968E2, 0x0)
On Fri 21/09/2012 19:01:24 GMT your computer crashed
crash dump file: C:\Windows\Minidump\092112-9594-01.dmp
This was probably caused by the following module: dxgmms1.sys (dxgmms1+0x28940)
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF88006FC3940, 0xFFFFF8800B95A940, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
On Fri 21/09/2012 17:16:50 GMT your computer crashed
crash dump file: C:\Windows\Minidump\092112-9625-01.dmp
This was probably caused by the following module: win32k.sys (win32k+0xE9E2A)
Bugcheck code: 0x3B (0xC000001D, 0xFFFFF96000159E2A, 0xFFFFF8800880C230, 0x0)
file path: C:\Windows\system32\win32k.sys
description: Multi-User Win32 Driver
On Fri 21/09/2012 12:43:50 GMT your computer crashed
crash dump file: C:\Windows\Minidump\092112-11325-01.dmp
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0x897180)
Bugcheck code: 0xBE (0xFFFFF8800F93F180, 0x800000028C431121, 0xFFFFF8800BB216C0, 0xB)
Error: ATTEMPTED_WRITE_TO_READONLY_MEMORY
Bug check description: This is issued if a driver attempts to write to a read-only memory segment.
Google query: nvlddmkm.sys NVIDIA Corporation ATTEMPTED_WRITE_TO_READONLY_MEMORY
On Thu 20/09/2012 22:41:07 GMT your computer crashed
crash dump file: C:\Windows\Minidump\092012-9250-01.dmp
This was probably caused by the following module: win32k.sys (win32k+0xCB301)
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF9600016B301, 0xFFFFF880067F6070, 0x0)
On Thu 20/09/2012 22:01:09 GMT your computer crashed
crash dump file: C:\Windows\Minidump\092012-9313-01.dmp
This was probably caused by the following module: dxgmms1.sys (dxgmms1+0x39AD0)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF88006D84AD0, 0xFFFFF880061FD938, 0xFFFFF880061FD190)
On Thu 20/09/2012 21:19:25 GMT your computer crashed
crash dump file: C:\Windows\Minidump\092012-9141-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1AB9BC)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF80002DC99BC, 0xFFFFF8800337E828, 0xFFFFF8800337E080)
On Thu 20/09/2012 21:06:13 GMT your computer crashed
crash dump file: C:\Windows\Minidump\092012-10998-01.dmp
Bugcheck code: 0x50 (0xFFFFF8800C9D2268, 0x0, 0xFFFFF80002C77E04, 0x0)
Conclusion
12 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
It is pointing towards your Nvidia drivers but you have freshly reinstalled everything. Maybe use driversweeper and uninstall all nvidia drivers and try again? Worth a shot. Also as it is random after say an hour, I would assume your temps are ok? Worth checking with AfterBurner to make sure.
