Graphics Upgrade
16 Sep 2006
In the vicinity
Hey guys,
Just bought a Mac Pro and was wondering which card would be best to upgrade to a dual DVI graphics card or just get a second GT 120?
Don't you need special graphics cards for Macs? I thought they had to have special firmware to cope with the EFI in a Mac.
You CAN get a normal GTX285 to work in Mac in conjunction with your GT120.
You need the GT120 still to get an output as the GTX285 doesn't output until OSX is loaded. macrumors is where to look if interested. May be worth sticking with an EVGA model though still from what I read quickly.
EVGA do a GTX285 for Mac which has a proper EFI implementation on and a £369 price as well. Is a proper Dual DVI card and works with screenoutput from boot, doesn't need to wait for OSX to load.
It is available with a 2-3 week delivery on the Apple Online Store, but isn't offered as a BTO.
Unless you need the performance you could just get a mini-dp to DVI cable to provide two DVI connections on the GT120. Would be cheaper then buying a second GT120. £68 vs £120.
