Graphics upgrade
21 Oct 2002
Sunderland
I currently have two KFA2 670 ex oc in sli supported by a 3770k running at 4.5Ghz.
I have major itch to upgrade but I have held off for now.
The plan was to upgrade to a haswell-e in June/August with 2 top end maxwells(880 I presume) running on 4k.
Since gaming quality 4k monitors are now available and the rumours of top end maxwell delayed until 2015 due to 20nm taking longer than expected; I'm considering getting a cost effective upgrade to graphics right now.
It seems 2 r9 290's would provide enough grunt for 4k while costing a quite reasonable £650.
Opinions ?
There was a thread earlier with someone asking about 2x7950's running a 4k panel. It would seem that while the AA will need to be kept at bay, it will be playable with enough grunt.
Have you considered keeping your 670s?
I have but I just don't think they will be up to the task. Most sites seem to believe you still need some form of AA when running 4k and it's seems silly to me to run 4k without running high/ultra settings.
I mostly play mmo's and although they are not very demanding they also don't make great use of sli/crossfire so more powerful individual cards would be the way to go I would think.
Opinions ?
To be honest, that would be the only sensible option to go considering performance vs cost.
I think it would probably struggle a bit for demanding games like Crysis 3, if we were using 4x or 8xMSAA...but with 4K res at 28", I really don't think you need that high level AA at all (you'd probably even struggle to tell the difference even between 0xAA and 2xAA).
I have taken some in-game screen shots and resized them to 1920x1080 (from 3840x2160) and used various levels of settings and AA. Apart from frame times, can you tell the difference?
BF4 looks good and is very demanding but for me, with AA off completely and even down to medium settings, it looks good (and gives me 200 fps). Don't read too much into needing AA, as with it off and on at 4K, it is damned hard to tell :)
