Graphing Perfmon stats? must be missing something obvious.
25 Mar 2004
Fareham
Hey guys,
I am capturing Performance data from perfmon for some of our Mailbox Servers into SQL. Everything with that is going fine. I can query the data etc.
The SQL table schema is this:
Code:
CREATE TABLE [dbo].[Perfmon_MBX]
	[ID] [int] IDENTITY(1,1) NOT NULL,
	[Server] [varchar](50) NULL,
	[ObjectName] [varchar](100) NULL,
	[CounterName] [varchar](100) NULL,
	[InstanceName] [varchar](100) NULL,
	[Value] [decimal](18, 3) NULL,
	[DateTime] [datetime] NULL
This is a typical query I am running to pull back data:
Code:
SELECT
Server,
ObjectName,
CounterName,
InstanceName,
Value,
DateTime
FROM Perfmon_MBX
WHERE ObjectName = 'logicaldisk'
AND CounterName = 'avg. disk sec/read'
AND InstanceName LIKE 'd:\databasefolder\dag1%'
AND Server = 'mailboxserver.domain.com'
AND DateTime > '2012-10-04 09:00:00'
AND DateTime < '2012-10-04 09:20:00'
ORDER BY InstanceName, DateTime
The data comes out like in this .csv file I've uploaded here:
http://ge.tt/1M7utuO/v/0?c
The problem I am having, is that each database (in the InstanceName column) needs to have a different series or line on the graph, I can't see an easy way to do this without manually adding all of the 10 series, which is a bit of waste of time, and this example is a cut down/simple one compared to reality.
Can anyone help me graph this data more easily using Excel?
Do I need to adjust my SQL query somehow, or is there an easy to do this in Excel?
If you need any more info please ask :)
