Hi, I habe a Rampage V extreme (the rog one) and on startup I'm getting error code 62 on the mobo, and no monitor output. The small red led for Graphics card remains lighted, whereas the others flash on and off.
I tried to boot the PC without the card in and got the code for no GC present. The CPU dont integrated graphis)
Can anyone else suggest anything else I should try before wrighting the card off and getting another. Its a NVIDIA GTX 980 by the way.
Edit I perhaps ought to say I detected some light oil, maybe lubricating oul, on the underside of the card and dripped onto the PSU. This probably wouldne have caused a short but maybe a fan bearing has gone?
Plus also, I have tried the card an the next PCI slot down and get the same error.
