- 3 Jul 2005
yes yes its me with another stupid post.
I was thinking, if you had a spring attached to the ground, which would compress very tightly, and you had a ball of a certain weight on the spring, if you released the spring and the ball shot up in the air, if it was the correct weight and the spring was the correct tightness could it fall back on the spring and bounce back up to a height where it would constantly bounce from the spring? Ive explained it terribly.
