Graw 2. Does it crash often for most people?
12 Sep 2003
Newcastle, UK
I've just got this game and twice now it's just froze up my PC. Not whilst playing the missions but both times it was whilst in the briefing section. :confused:
Driver wise I have been using the latest official nvidia drivers, but I've now tried the latest beta's and it still does it.
Just wondering if anyone else has this problem and/or a fix?
Oh yeah, also does AA work for people in this game?
Sorry if re-post... just noticed the search button is gone! :o
Thanks!
You can't enable AA, not even from control panel. Atleast I've never been able to as it's a engine limitation.
It crashes a fair bit for me as well, quite annoying.
Been using 158.45 Nvidia drivers and it seems to work alright, I get graphical problems on any newer driver.
Its crashed twice on the same part of the game. I'm using the game unpatched as when I used the auto installer it said i was using the wrong version of patch.
About 8 hours of gameplay with two crashes is not too bad I'm running core2duo 6600, 4 gig of ram, 8800 gts and vista.
plays superb for me never crashed tbh
forcing aa 8xQ in control panel and it never drops below 30 but usually sits at 60fps with vsync as well
Thanks for the help. :)
Just found out that by lowering Dynamic Lighting to LOW it cures the crashing, well, not totally, but it's not happening half as often. :D
We had one of the devs over at i31 giving a talk about GRAW 2. Its not just MP fixes with each patch, its also a lot of optimisation of the game to take advantage of multi-core CPUs.
Yep, I got a crash on the first level, the image froze and the sound was all corrupted, I had to press the reset button to get back to the desktop.
I just uninstalled this game last weekend
I enjoyed it even though I had to put up with it crashing at times. But the final blow for me came from the dam mission, when the 2 choppers came I cleared out the troops that come from no-where and run across the street to the building with the RPG's in it, now if I died on my first attempt or missed the choppers with the rockets every attempt after that the RPG's would be empty or not there at all, I would have to restart the game. So annoying after about 30 goes having to try and do this part with one go it was simply uninstalled and put back on the shelf where ARMA has sat since febuary.
