Graw 2 XBL problem
Caporegime
9 May 2005
Cambridge
I'm having issues with finding games of multiplayer Graw2. I have recently changed provider from cable to adsl. Most other games seem fine, after some tinkering I got my NAT from strict to open.
Yet when I search for games of graw 2 I get one or two games max. Most of the time I get none. I've even tried putting the 360 in a DMZ. Same result. Yet if I search for games of hockey or Uno I see loads of available games.
As graw is my most played game I would like to know what ADSL routers others are using that play this game. Then I will think about binning the homehub I have.
When I was on ntl I had a Linksys54g that was faultless, anyone with an adsl linksys they can recommend for the xbox?
Really, where did you read that?
Just tried the original graw and no issues. Just trying GOW now and no problems finding games for that.
dannyjo22 said:
Well seems you are correct until I've read all the thread here....
http://forums.xbox.com/11801765/ShowPost.aspx
Thanks for that. I will read the whole thread see what I come up with. I asked nokkon earlier to do a search on his 360 using Bt and he didnt find many games either. I thought it was a router problem, seems not.
I have the new map ill have a look online now see if i can find any... ill get back to ya
Thanks mate does seem to be a bug they are working on looking through that xbox thread. Deleting nowhere seems to cure it. I hope a few more ocukers could give the game search a try for me see what they get???
Miss K?
Ceeg?
Alrik?
Once a few have tried I might try deleting nowhere see what I get.
Ok had a look an player match then any game type cant find 1 game
soon as i Deleted that new map i see 1 game on there 8/16 players but thats it :confused:
sure there will be more people playing than this
Looking through the thread, Ubisoft have aknowledged the problem and are working to resolve it. I think people have also abandoned playing til its fixed.
Also it seems for a while MS and Ubi blaimed each other.
I was going to play last friday night and had no game available come up and it did seem a bit odd because i had never had that before , i will try deleting the map and have another go sometime .
Yeah last night I thought. Time to fire up the old Graw2. Noticed my router had gone to strict so i reset it. When I couldnt find any games assumed the worst that the router was causing me grief.
Really fancied a game too :(
Deleted nowhere and its now searching and finding games as it should, weird.
Oh well gonna play some graw again tommorow if anyone wants a game.
Just post a time tommorrow and i'll have a game.
me2, just used that fix and now a good few games are appearing...
but i keep getting ejected from the servers and all? No reason why but it happens EVERYTIME! My rank also seems to have been reset, did this happen with an update? Is my progress towards achievements now knocked way back too?
The problem is not your ISP or router, its the fact this was a flash in the pan game, as predicted by yours truly*.
*The Nowhere map may have exaggerated this problem though.
