GRAW Help
7 Oct 2005
Hey all,
Im stuck on the Road block level where your on the roof, ive cleared the enemy base and the tank can't go any further but i dont get an update, all i can do is go back on myself.
Any tips?
Thanks
Where the tanks stop u have those buildings on the right... U have enemies near them keep looking towards the center of the two blocks of buildings and they **** pop up as the red diamond things. Then you get ya tank to attack them.
keep checking m8 go to the point on the roof where ure in line with the tanks on the road and look to the right at the buildings, its a bug in the game took me ages to work out. I think they are actually around the corner on the road
Doh theres no one popping up, maybe i did it in the wrong order, i sort of went all the way accross the roof then came back and did the first road block then did the second.
yup i had a bug on this when replaying on Normal, and the tanks wouldnt go properly meaning i couldnt hit the checkpoint, had to restart it
