Had both the RV02 briefly(lots of faults, dodgey case from manufacturer) but also hated it, got a HAF X instead, mostly better all around. Better hdd mounts, less cramped case, easier cable management, more adaptable, more room for watercooling if thats your thing, FAR more room for sli/xfire, better room for longer/bigger PSU's.
Frankly its better all around, unfortunately the RV02-e is almost as expensive as the aluminium version which is a touch frustrating, though thats in large part down to the penetrator fans being included which are, honestly, overly expensive, even though standard 180mm Silverstone fans cost about as much as penetrators in retail so a bit of a joke.
I like the Raven's design, its just needlessly small, 2-3 expansion slot deeper, 2-3 inches higher and it would still be a compact case but with a good design.
A none broken RV02 is a nice looking case, and I'd say great for a non high end computer, but if you're thinking about sli/xfire, or watercooling, the RV02 is just too small in every direction.
