** Great Cooler @ Great Price **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
As many of you may be aware, the Prolimatech Megahalems is a beast of a CPU cooler.
The Megahalems is more than capable of taming the heat output of even the most demanding CPUs.
We use a variant of the Megahalems in our system builds which actually comes with a fan. The Prolimatech 81 uses slightly different materials to the Megahalems but performs within a few degrees of the flagship cooler from Prolimatech. The bonus is that it comes with a fan, the drawback is the limitations of only using 115X socket hardware out of the box.
The Megahalems is £42.98 and is currently out of stock in Europe.
The Prolimatech 81 is in plentiful supply at OcUK and is priced at £34.99
On Wednesday (17/06/15) we are dropping the price of the Prolimatech 81 to £28.99 on our this week only deals.
Prolimatech 81 CPU Cooler - 120mm @ £34.99 inc VAT
The Basic 81 features six high quality heat pipes and one PWM 120mm Double-Ball bearing fan. Its large size offers excellent cooling ability and is capable of providing intensive heat dissipation. Intel compatible only.
The Basic Series offers competitive solid performance at a budget level price! They are designed to be affordable while still maintaining the reliable quality you've come to expect from us. They are an excellent option for replacing stock coolers in any system, for improved cooling, quieter operation, and even overclocking! Check out the 5 different models to find the perfect cooler for your hardware, be it small media centers to massive hungry processors!
- Dimensions: 130 x 158 x 75 mm (W x H x D)
- Material: Nickel plated copper (heat pipes), Copper (base plate), aluminum (blades, base plate)
- Weight: about 748 g
- Heatpipes: 6 x 6 mm dia
- Fan: 1x 120mm
- Connector: 4-pin PWM
- speed: 900 - 1600 r / min (+ / - 10%)
- Compatibility:
Only £34.99 inc VAT.
ORDER NOW
I may be wrong then. the info I had was for the first revision. will check when i get back to work anyway.
it would easily handle 2011 TDP so I guess it makes sense that it includes it.
either way, its a LOT of cooler for the money
I was actually thinking of downsizing from my current alpenfohn k2. Considering a megahelims as I've used one before. Great price on this.
