***** Great Deal ***** Antec 300 Case with an Antec Basiq Plus 550W Modular PSU
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
OcUK have got a unique deal available for you!
Impressively spacious and unbeatably reliable, the Antec Three Hundred is an unbeatable enclosure. Despite its eminently portable frame, the Three Hundred has enough room for the latest flag ship GFX cards, as well as six hard drives and a standardATX motherboard. A cable management compartment keeps your system organized and the airflow unobstructed. A 120mm rear fan and 140mm top fan ensure that the case runs cool even when playing the most demanding games, while the sleek black finish gives it an extra stylish edge.
- External 3 x 5.25"
- Internal 6 x 3.5" for HDD
- 1 rear 120 x 25 mm TriCool™ Fan with 3-speed switch control.
- 1 top special 140 x 25 mm TriCool™ Fan with 3-speed switch control
- 2 front (optional) 120 mm fans to cool the hard drives
- 1 side (Optional) 120 x 25 mm Fan to cool graphic cards
- Washable air filters reduces dust build up in your system, which helps keep your system cooler
- Perforated front bezel for maximum air intake
- 7 expansion slots
- Top mounted I/O ports for easy access
- 2 x USB 2.0
- Dimensions: 458mm (H) x 465mm (D) x 205mm (W)
- HDA & AC’97 Audio In and Out
The ideal choice in high-quality value-priced power supplies, now with advanced cable management! The Basic 550 Plus is the perfect power supply for the entry-level user, providing stable power, quiet cooling, and advanced cable management for improved airflow and ease-of-use.
- Advanced cable management for improved airflow and ease of use
- ATX12V version 2.2
- 120mm low noise cooling fan
- Heavy duty protection circuitry prevents damage resulting from short circuits, over currents, over voltages, and other dangers
- Universal input with active PFC
- SATA connectors for Serial ATA drive
- MTBF: 100,000 hours
- Safety approval: UL, CE, TÜV, CB, FCC, CCC, C-TICK
- Backed by a 3 year parts and labour warranty
- Unit dimensions: 8.6cm(H) x 15cm(W) x 15.5cm(D)
ONLY £89.99 Inc VAT
