- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys
We have a new entry level aftermarket cooler which does perform very well, beatiing both the Freezer 7 Pro from Arctic Cooling and the TX3 Evo from Cooler Master. It's lower in price too - why would you not buy this?
Alpenföhn Civetta CPU Cooler (Socket LGA775/1156/1155/AM2/AM2(+)/AM3/FM1) @ £15.98 inc VAT
Small size, low cost and best compatibility. These had been the three main attentions in developing the new multi-socket tower cooler Civetta.The heatsink is based on the award winning HDC architecture. By using this technology the heat coming from the CPU will be directly transfered through the heatpipes to the aluminium fins. This results in a better performance especially for compact sized coolers.
Furthermore Alpenföhn designed closed front faces. This leads to more stability as well as creating a "wind tunnel" to direct the airflow through the fin package. The fan used has a 4-PIN header to be controlled by the mainboard. This ensures best possible speed control from 800 to 2.800 rpm generating a minimum noise of 16.7 dB(A) and a maximum airflow of 85 m³/h (50 cfm).
- H.D.C (heatpipe direct contact) technology
- 3 pcs high performance heatpipe
- 92mm PWM fan
- Multi-socket tower (Intel/AMD)
- Light wight
- Cooler Size: 105x78x129mm
- Fan Size 92x92x25mm
- Fan Noise: 22.9 dBA
- Airflow: 85,67 m³/h
Only £15.98 inc VAT.
ORDER NOW
- 92mm PWM fan
- Light wight
ORDER NOW
