*** Great price on 6 TB Western Digital RED £179.99 ***
7 Feb 2011
Stoke on Toast
Well these are outside due to be booked in anytime.
Western Digital Caviar Red 6TB SATA 6Gb/s 64MB CacheTB SATA 6Gb/s 64MB Cache HDD - OEM WD60EFRX @ £179.99 inc VAT
WD Red is the only hard drive designed for NAS systems that have 1-5 drive bays. WD Red is designed specifically for home and small office NAS systems. The drives are extensively tested for compatibility and reliability in the demanding operating environment of a 24x7 NAS system. WD's exclusive NASware firmware technology enables seamless integration and balanced performance. Innovative technology reduces power consumption and lowers the operating temperature, and with a 35% improvement in MTBF over desktop drives, WD Red is a more reliable and robust NAS hard drive solution.
Main Features:
- Reduced power consumption - WD has reduced power consumption making it possible for our energy-conscious customers to build systems with higher capacities and the right balance of system performance, ensured reliability, and energy conservation
- Cool and quiet - Drives with WD GreenPower Technology yield lower operating temperatures for increased reliability and low acoustics for ultra-quiet PCs and external drives
- Perfect for external drives - External drive manufacturers can eliminate the need for a fan in a high-capacity product by utilizing the cool and quiet operation of WD Caviar Green hard drives
- IntelliPower - A fine-tuned balance of spin speed, transfer rate and caching algorithms designed to deliver both significant power savings and solid performance. Additionally, WD Caviar Green drives consume less current during startup allowing lower peak loads on systems as they are booted
- IntelliSeek - Calculates optimum seek speeds to lower power consumption, noise and vibration. View demo >
- Advanced Format (AF) - Technology being adopted by WD and other drive manufacturers as one of multiple ways to continue growing hard drive capacities. AF is a more efficient media format that enables increased areal densities. (RS and RSDTL models only)
- NAS compatibility
- Enhanced reliability
- The secret is in the technology-NASware
- Energy efficient
- 3D Active Balance Plus
- Premium support
- Longer warranty coverage
Specifications:-
- Form Factor: 3.5 inch Hard Drive
- Enclosure type: Internal
- Disk Capacity: 6000 GB
- Drive Interface: SATA 6Gb/s
- Data Buffer/RAM: 64 MB
- Operating Temperature: 0 to 70 °C
- Non Operating Temperature: -40 to 70 °C
- Shock (Operating): 30Gs for 2ms
- Shock (Non Operating): 300G for 2ms
- Acoustics (Seek Mode): 25 dB
- Acoustics (Idle Mode): 24 dB
- Weight: 0.60 kg
Only £179.99 inc VAT.
ORDER NOW
