Hi there
AOC have released two incredible value FREESYNC enabled monitors, but forgetting FREESYNC in general the specification on these monitors is also very impressive for the prices with 1ms response time and great connectivity, so ideal for both AMD and NVIDIA graphics solutions.
AOC G2260VWQ6 22" 1920x1080 TN FREESYNC 1ms Gaming Widescreen LED Monitor - Black/Red @ £99.95 inc VAT
This AOC G2460VQ6 monitor is perfect for endless gaming sessions. With one milisecond response time high precision gaming is guarenteed while the newly introduced Anti-Blue Light Technology reduces the strain on the eyes. By shifting the blue light instead of filtering it out, the colours remain true. Additionally AOC’s Flicker FREE reduces the strain on the eye even further. This means the gaming experience is as brilliant as ever, perfected by advanced eye protection. Together with AMD FreeSync™ this monitor ensures great visuals and full detail without image tearing or blurring. Countless hours of gaming are no problem anymore!
AMD FreeSync™ enables a seamless synchronization of GPU and monitor refresh rates without sacrificing performance at an affordable price. This technology delivers a gaming experience with zero tearing,zero stuttering and zero input lag while keeping the framerates at maximum level. AMD achieves this by utilizing the industry standard DisplayPort™ Adaptive-Sync to enable dynamic refresh rates. That means the GPU is communicating with the monitor simultaneously to sending a new frame or image, leading to a perfect synchronization between both devices. Gamers only need a compatible AMD Radeon™ graphics card, a FreeSync™ enabled AMD Catalyst™ driver, plus a supporting gaming monitor and they are equipped to enjoy the smoothest gaming ever experienced.
A pixel response time of 1ms GTG means speed without the smear for an enhanced gaming experience. Fast-moving action and dramatic transitions will be rendered smoothly without the annoying effects of ghosting. Choose the right path to success, don’t let a slow display stop you.
Multimedia-Ready with HDMI Input - HDMI (High-Definition Multimedia Interface) enables you to connect a secondary device to your monitor with up to 60 Hz. Switch between your PC and console on the fly to experience a huge variety of new possibilities playing all your favorite games, on all your favorite devices.
Specification:-
- Monitor Size: 21.5"
- Visible Screen Size: 54.6 cm
- Screen Format: 16:9
- Brightness: 250 (typ) cd/m² (typ)
- Contrast Ratio Dynamic: 200,000,000:1 (DCR)
- Contrast Ratio Typical: 1000:1
- Viewing Angle: 170° /160° (CR 10)
- Response Time: 1 ms
- Maximum Resolution: 1920 x 1080@ 60-75 Hz
- Recommend Resolution: 1920 x 1080@60-75 Hz
- Colors: 16.7M
- HDCP compatible: Yes
- Inputs: Analogue, HDMI & DisplayPort
- Dimensions (WxHxD): 511.8 x 376.95 x 185 mm
- Freesync Supported
- Compatible with NVIDIA & AMD Graphics Cards (Only AMD Supports FREESYNC)
- Blue Light Technology
- Flicker Free Technology
- Warranty: 3yr (On-Site with AOC - 0808 234 3510)
Only £99.95 inc VAT.
ORDER NOW
AOC G2460VQ6 24" 1920x1080 TN FREESYNC 1ms Gaming Widescreen LED Monitor - Black/Red @ £129.95 inc VAT
Specification:-
- Monitor Size: 24"
- Colors: 16.7M
- Dimensions (WxHxD): 565.4 x 411.6 x 219.3 mm
- Stereo Speakers (2x2W)
Only £129.95 inc VAT.
ORDER NOW
VIEW OUR ENTIRE RANGE OF FREESYNC MONITORS!
Specification:-
- Colors: 16.7M
ORDER NOW
Specification:-
- Monitor Size: 24"
- Colors: 16.7M
ORDER NOW
Great prices though!
