Green and White Antec P120 Build
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey all.
My new PC build is finally done.
Spec
Antec P120 Crystal White Edition Case
AMD 3900X CPU
Palit RTX 3080 OC
Asrock X570 Steel Legend
512GB ADATA m.2 MVNE Drive
6 x Antec 120mm Prizm fans with hubs.
2TB Samsung SSD
1TB Samsung SSD
32GB 3200mhz RAM.
EKWB Coolstream SE 360mm rad
EKWB Coolstream PE 360mm rad
EKWB Plexi Vector GPU Block
EKWB Vector active GPU backplate
EKWB D5 PWM Pump and Res combi
Alphacool CPU Block
Cable mods green cables.
2 x Dell 30" 4K IPS Curved screens
I decided to go green theme which works well with the white case and wall behind. I think it turned out well.
Nice, the P120 is one of Antecs better cases, i have the same one in Black on my second PC, its good build quality, shame they have fallen out of favour with OCUK
Ah it's good to see a fellow soft hose build for a change, the green and white go very well together.
