Green Corsair 540 Carbide
4 Dec 2013
Hi
New to OC but have been building PC's since I was about 12.
This is the current set up but i'm looking to upgrade to dual 4K displays so going to need some more fire-power graphics wise
The Bits
Desk Set Up
Cards
CPU Cooling
Dusty Flash on Shot!
Specs:
i7 4770K Watercooled with H100i
16GB Corsair DDR3 1800Mhz
2 x OCZ 256GB Sata3 SSD's
2 x OCZ Bigfoot Vertex2 Sata2 468GB
2 x EVGA 770GTX SC 2048GB
2 x 28" Asus LED Monitors
Razer Deathstalker
Steelseries 9D Mouse Mat
Steelseries Siberia2 USB
Steelseries Siberia2 3.5mm
Razer Ouroboros Wired
Needs more green mate:p:D
Yeah I did have Green LED Backlighting. but it was just to much of a Geeky Green Fest!
The desk setup doesnt exactly impress ladies anyway; I Normally lie and say I Need it for work!
Compressed air on them fans too! ;)
On the list; I was always advised not to as it damages components?!
Debating ordering 2 x 780ti's but doubt these would be good enough for 4K; Could go TitanZ I suppose...
What's your budget for GPUs? Dual 4K, literally no setup will be maxing the latest games.
Thanks for your post.
I will only be playing games on one screen as I do now and have music on the left screen. I currently play BF4 on Ultra with 130% Resolution Scale at around 80-120FPS. so somthing that could do the same but at 4K resolution.
Initial Budget was about 2k with the monitor - Otherwise I Don't think I can justify the money
I thought push pull was a good idea!:rolleyes:
Thanks for the kind words; Anyone think of any improvements I should be making?
Yeah. Fix that fan direction issue. You're just recycling the hot air from the rad that way. Push/pull would require 4 fans in that circumstance. Two pushing on one side of the rad, and the other two pulling on the other side. :)
And get rid of all that dust, it will help impress the ladies. ;)
Disregard TitanZ it is such a stupid card at its current price.
Dual Titan blacks are both cheaper and look better.
Or purchase 3 290x's if you want to try amd.
Agree with everything you've said, DON'T even think about buying a TitanZ, WAY to overpriced and you can get a more power setup for much less money. If you want to stick with Nvidia, then dual Titan Blacks are the way to go. If you don't mind trying AMD, then a R9 295 X2 is half the price of a TitanZ or like has been said above three R9 290x's
