Hello fellow ocukers, it's that upgrade time for again so looking to be placing a nice order at ocuk.
My current system is (which has lasted me very very well):
Q6600 @ 3.4ghz
6gb crucial ddr2 ram
150gb WD Raptor Drive
4tb storage capacity
ati 5850
for day to day normal pc activities, this system is running fine. However i have started doing a lot of photoshop and adobe after effects/premiere pro work and its starting to annoy me at how slow the encode times take. My friend has an i7 clocked to 4.2 and it is so much quicker to encode the same movies etc.
I am a big fan of overclocking and i love spending hours/days finding the best clock and stability. The Q6600 i loved because i felt it gave the best bang for my buck. Looking for the same kind of current chip for this build. I saw that 5ghz oc sandybridge thread and that would be nice. Is that possible on air?
What i need is basically a new system. I will be keeping the current pc, so I will be needing a new case etc and all the stuff that goes in it.
Cpu: great overclocking potential. able to munch through encoding
ram: what amount is good for encoding
16gb overkill?
gfx: i will want to game but its not a priority, something max £200 ish. Would like it to be able to encode adobe to take some stress off the cpu.
case: something big and roomy. I think my current case is an antec 1200.#]
budget: nothing that will break the bank but £1000-£1200 is good.
no monitor keyboard or any other peripherals needed.
Thanks in advance guys.
Q6600 @ 3.4ghz
ati 5850
16gb overkill?gfx: i will want to game but its not a priority, something max £200 ish. Would like it to be able to encode adobe to take some stress off the cpu.
