grey screen crash problems...HELP!
8 Feb 2021
YEAR OLD PC and having issues
For the past few weeks, I have been experiencing many moments where I will be on my pc and the monitor suddenly goes gray and unresponsive. The actual computer doesn't change at all; the lights are still on, the fans are still running, and no weird noises come from it. The monitor stays gray until I shut off my pc with the power button and boot it up again, which fixes it until the next time it happens. It happens at completely random times; windows always boots fine and it could happen after hours of playing video games when i close the game or i can just be on the desktop, click something and it will do it again. The frequency at which these crashes happen is also random and no pattern. can be after 5 mins or 2 hours. and most of the time when i close a game but also when just on desktop.
last night it did it 5 times in 30 mins
so far i have updated amd drivers and windows update - no change
ran DDU -no change
ran complete system restore inc clean disk - no change
upgraded to windows 11 - no change
installled another 1tb drive - c drive is now purely OS - no change
installed new western digital sn750 for games (no change
ran memtest - no change
other thing worth noting is that since i built the pc the monitor occasionally loses display port signal, i put this down to a loose connection so purchased some new locking display port leads which solved the issue.
also the monitor samsung odyessey g7 32" will not update the firmware so wondering if this could be an issue also?
really am lost as to what to do now as the pc is only a year old since i built it and this has just started happening, ive changed nothing and havent installed any copied programmes or anything like that at all.
is it worth trying a different monitor?
if someone could help it would be hugely appreciated.
spec is as follows
msi radeon rx 6800xt
amd ryzen 7 5800x
be quiet dark rock cooler
msi mag x570 tomahawk wifi atx am4
corsair vengeance rgb pro 32gb
western digital sn550 (OS)
western digital sn750 (games) installed yesterday
corsair rmx 750 80+ gold
Do you have a spare gpu to try or monitor it will rule things in or out ?
Also could try older drivers before the problem started.
Have you tried the DP IN 2 and the hdmi ports of the monitor to rule out if the DP IN 1 port is not faulty?
I've tried both ports on the monitor, am going to try another DP lead tonight and also a different port on the GPU.
other than that I've told to try pulling the GPU and connect via hdmi and see if it still happens on the integrated graphics
He means your CPU (5800x) doesn't have integrated graphics, so if you pull out your GPU (6800xt) you won't have any display from your motherboard display out.
Do you have the 2x8 pin psu connectors in place securely?
it would be ideal having a 2nd gpu available to test.
Also check event viewer as others have said, it'll hopefully give some hints
Sorry course he does, my mistake...
Yes everything appears to be okay and has been working brilliantly until 3 weeks ago when all this started..
The pc only gets light use as well so I'm a bit baffled tbh
so....
I've tried different leads and all display ports on the gpu and no change..
then used the HDMI port on the gpu to the monitor and no grey screens as of yet..
any ideas?
hdmi is fine but can only go up to 144hz. is there any other negatives to using hdmi?
so....
any ideas?
Did you try older drivers ?
