Grid Demo Problems
8 Feb 2008
Edinburgh
I'm using the Thrustmaster 360 Modena Pro. It works fine configuring the controls in-game and I set it to use my custom control set up. However, when I start a race my car just sits there and nothing I do seem to do works. My wheel works fine in Toca Race Driver 3 so I don't think it's a wheel issue.
Windows XP SP2
E8400 3.0GHz
8800 GTS 512MB
2GB RAM
Here's a screenie of my controls set-up screen.
Any help much appreciated :)
When you set controls, did you set everything up and then for whatever reason have to close the game and come back to it later? With my PS2 pad every time I launch the game I have to go back into controls and remap one of the buttons, everything looks like it's set up and Custom is ticked, but it wont work until I remap just one button. It's bizzare.
PS. Screen grabs ftw :p
I use an xbox360 gamepad and do not have any problems.
I can play the game in the morning then go back and play again later in the day and all the settings stay the same
I can't get my Modena 360 to function in it either. Doesn't even let me bind wheel inputs from that custom controls screen.
Only thing out of the ordinary is I'm using a gamepad port > USB converter, however it's picked up fine in game controllers and works great in Flatout 2 among others.
That doesn't count, the 360 controller is set up for flawless use out of the box and anyway, what I described happens to me every time. It might be the same for him.
Same for me. :) Have to re-map a button to make it recognise the controller.
Took me awhile to figure that out. lol.
