Grid Stuck on Grid Logo
9 Dec 2006
@ManCave
I installed Grid updated to v1.2 and got blank screen issue,
Reinstalled to V1.00 and i can run it but it just stays on the grid logo.
is there any ideas on how to fix this there isnt anything on codemasters forums :(
found a lot of threads on the grid forum with that problem and tons of fixes. the thing that worked for me was uninstalling daemon tools.
Turn off the GX mode.
I have a D2X same as you and some games I had to turn it off GX mode and others I had to enable it before it would run.
Worst thing is there is no profile system so you have to remember which games is compatiable with it and which are not.
Had this problem and managed to fix it. It's the processor. Turn off HT and try again. It should work. Not sure what the issue with HT is, but Grid doesn't like it.
Cheers,
Blue
