Grid - Ultra High Mod!
21 Jan 2003
Torquay - Devon
just installed the game and want the ultra high mod to test my 4850!!
could anyone give me a link please as ive found 3 links so far and they all been dead links, also where did i extract the file to?
thanks for being dumb!
Westie
x
Now then Westie! Its Jack! Good to see you got Grid my son! Me and Sudders and some randoms off overlcockers are gona group up tonight and use vent etc. Also iw ill be sorting myself out with the ultra mod when i get in from work so i will link you to it then! So anyway see you on Si's vent at about 6ish matey ;)
P.S. it's a small world ;)
P.P.S. I see you found my other post already about the race im organising for tonight! Right im setting off on my commute home in a minute so ill be online at about 6ish
An Ultra HQ modified files pack was posted on SA by IcemanZero
Quote -
Here is my Ultra High Pack. Visible Objects are maxed out, so are shadows and some AA. Just overwrite with your configuration. Start the game choose your resolution, everything should work fine. (BACKUP YOUR OWN FILES)
http://rapidshare.com/files/119545488/Ultra_High_Full.rar.html
Here are some pp changes (lighting etc) for the tracks.
http://rapidshare.com/files/119546867/ModV2.rar.html
config for POS systems on its way
Edit: Performance Pack for the "lower" end systems
http://rapidshare.com/files/119547139/Performance.rar.html
I tried this but had to revert back to my .backup files. When loading a race the screen just does not enter the race. Sits with the loading... please wait circle going around and around. :(
i cant see any difference between the original max settings and the Ultra Mod, gfx look the same and performance is the same ??
