Spent about 3 hours this evening trying to sort out a relations phones.
Line is totally dead, no line tone, no ringing when somebody dials in.
I open up the master box and incoming junction box, omfg, think this stuff was fitted before the war (hastings 1066 to be exact)
Prehistoric wire, damn stuff snaps off if you do it up in the screws too tight.
Middle pic - Red is the current active line. Yellow is an old 2nd line that has been disconnected since they moved in 15ish years ago. Green is a (suspected) bodge to use the circuit of the second phone line as an extension to the main circuit.
It looks a bit of a bundle as they're running a spur off the master to run another handful of sockets on the upper floors.
Things are behaving very strangely, if i connect a master box to the incoming line, there is nothing,, if i connect a new master box to the cables shown (the white, white & white coding REALLY helps sort things out) i can either get constant ringing or ringing which continues to ring (in the ear piece) when i pick it up. I can dial in to the number but it doesn't stop ringing when i pick up the handset.
What have i done wrong, i've had a brain fart and stopped fiddling until i can get a clear impression of what i'm doing. I'm sure the fudged secondary circuit is causing a problem, but i don't know where it runs to, goes down the wall and vanishes under the carpet.
Any ideas?
Cheers.
Any ideas?
Cheers.
